ISIS Proteus AT89C52 on many projects where you can test with three simulations ready proteus isis ISIS Proteus AT89C52 Proteus isis test set simulation. RAM, ISIS Proteus AT89C52 LCD, adc pwm ISIS Proteus AT89C52 LED serial port, display, ISIS Proteus AT89C52 keypad input output port s has a lot to do so and property to make the necessary settings in the hex file.
AT89C52 Proteus isis files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22056.zip
Published: 2013/08/06 Tags: development board projects
TDA1554 4X11W Amplifier Circuit 2X22 W
TDA1554 amplifier circuits made in the previous post was shared with more flexible PCB design this circuit TDA1554 prepared accordingly asks the integrated 4 × 11 watts of output you want 4 2 outputs can be used as 2 × 22 watts.
4 channel audio input to output TDA1554 is used as 1,2,17,18 legs all the series 0.22uF (220nF) capacitor at the output of the connected speakers 6,8,10,12 50v 1000uf capacitors connected in series in the legs
AT89C52 isis Proteus Simulation Test-Set
ISIS Proteus AT89C52 auf viele Projekte, in denen Sie testen können, mit drei Simulationen bereit proteus isis ISIS Proteus AT89C52 Proteus isis-test-set simulation. RAM, ISIS Proteus AT89C52 LCD, adc, pwm ISIS Proteus AT89C52 LED serielle Schnittstelle, display, ISIS Proteus AT89C52-Tastatur-Eingabe-Ausgabe-port s hat eine Menge zu tun, und die Eigenschaft, um die notwendigen Einstellungen in der hex-Datei.
