GLCD Animation circuit voltage is applied to the currently displayed map of Turkey comes first. Subsequently, the Turkish flag and a picture of Mustafa Kemal Atatürk, the next step is to come. Art world will begin to come after arrival.
Circuit operation: Graphic LCD as the most important feature point-based study. So, as in LCDs text and text can be printed as well as shape can be drawn. Half-P2 as data output port ayarlanmıştır.p1_0 end graphic LCD’s CS1, CS2 end P1_1 port is connected to the graphic LCD. Graphic Lcd structure is divided into 2 sections, including the right and left.
LCD Animation Schematic
8051 Graphic LCD Animation proteus isis simulation schematic keil source code:
Published: 2008/05/22 Tags: 8051 example, avr project, keil example, microcontroller projects
Calculation of Body Length with 8051 and DS89C430
In this project, which is designed using DALLAS DS89C430 microcontroller (in simulation AT89C51RC2) circuit and a marching band, calculated on the length of the body, the LCD display was performed.
Circuit consists of three parts.
In the first part, designed with the supply voltage for regulating the voltage source 7805 is used.
In the second part of the object on the moving walkway Fototransistörl sensor for detecting the sensor circuit can be used.
The third part of the circuit consists of a portion of the 8051 microcontroller and LCD.
