ADC 0808 standard data acquisition systems many components on a single chip host is a member of ADC 0808 8-bit flip makes the process and addresses from input latch 8-channel data selection (multiplexer) and microprocessor compatible with the associated control logic provides.
89C51 8051 voltmeter thermometer DS1621 ADC0808 Proteus isis simulation pcb keil source code author: Serkan SARIKAYA
Published: 2008/05/17 Tags: 8051 example, avr project, keil example, microcontroller projects
Stereo VU-Meter Circuit 100-LED
vu meter circuit lm339 12 LM393 opamp 1 used 50 LEDs per channel falls on the pcb drawings have all the parts available in the market
is on the Internet a lot, but the indicator with more than 15 LED Unfortunately, I have found. 2 x 50 LED. I have decided therefore to the design of a simple and relatively cheap indicator with 2 x 50 LED.
