AT89C51 L293D Motor Control Project
| July 13, 2023 Updated
AT89C51 L293D Motor Control Circuit Operation, Our project name and the name suggests, the treadmill is the motor control is required. When designing this project, I saw fit to use DC motors. Because the use of DC motors and have come to the fore in terms of ease of feeding.
An integrated circuit for driving DC motors, which use integrated’ve L293D. Integrated amplifier comprising transistors that are inside. Further information about Integrated PDFs are also available. As for operation of the circuit, in this embodiment via PWM DC motor speed control performed to obtain the sign amaçlanmaktadır.pwm Scheduler \ counter and timer 0 is used, so that a stone is set at 1 ms.
AT89C51 L293D Motor Control Schematic
kosu_bandi-150x150
AT89C51 L293D Motor Control Project keil source code proteus isis simulation schematic files: author: Mehmet ŞENTÜRK
Published: 2008/09/24 Tags: ,
1 Comment “AT89C51 L293D Motor Control Project
    2X30 Volt 300Watt Switch Mode Power Supply TOP250Y
    TOP250Y of integrated circuits based on the SMPS PCB Power Integrations schema files are also engaged in the production of other models can be used free design TOP250Y and detailed information
    1: Practical arrangements for the replacement of discrete components: TOPSwitch provides greater reliability and smaller size than the scheme on discrete components. MOSFET- EMI. The special scheme of management power MOSFET-transistor reduces EMI.
