4 Piece AT89C2051 microcontroller project has been realized with matrix display isis proteus simulation and asm files available in hex code
Atmel AT89C2051
• Compatible with MCS®-51Products
• 2K Bytes of Reprogrammable Flash Memory
– Endurance: 10,000 Write/Erase Cycles
• 2.7V to 6V Operating Range
• Fully Static Operation: 0 Hz to 24 MHz
• Two-level Program Memory Lock
• 128 x 8-bit Internal RAM
• 15 Programmable I/O Lines
• Two 16-bit Timer/Counters
• Six Interrupt Sources
• Programmable Serial UART Channel
• Direct LED Drive Outputs
• On-chip Analog Comparator
• Low-power Idle and Power-down Modes
• Green (Pb/Halide-free) Packaging Option
AT89C2051 Dot Matrix Display Applications asm, hex and protues isis simulation files
Published: 2008/11/06 Tags: avr project, microcontroller projects
PIC16F84 Multi Siren Sounds Circuit
16 different alarm sound circuit, after running the simulation of the fourth line of dip switches in different positions can run by selecting the 4 × 4 = 16 different sound Remember to press the reset button at the end of each selection. Original ASM file is available.
Example PICmicro Sounds: Police, telephone, IEP, buzzer,laser, etc.
Siren Sounds Circuit Schematic
