The Single-chip 16/32-bit microcontroller LPC2138 is an ARM7 microcontroller from NXP in a 64pin housing a wealth of peripherals, and myself as a basis for control projects. The board is described in an area of 100mm x 75mm functions
– An LCD port
– einen JTAG Port — A JTAG port
– Power supply 5V and 3.3V
– Voltage regulator as TO220 or SOT223
– 2x UART with RS232 transceiver
– Space for a 3V lithium battery
– A signal
– A real-time clock
– All I / O ports are placed on posts plug
LPC2138 development board
Source: http://www.viricom.de/viritec/elektronik/page5_files/category-mikrocontroller.html LPC2138 Universal Control Board pcb schematic alternative link:
ARM7 LPC2138 Universal Control Board
Publication date: 2008/08/28 Tags: avr development board, development board projects
8051 Sample Application and 8051 Development Board
The 8051 development board provides an easy-to-use and low-cost way to develop your 8051 based microcontroller projects, without purchasing any other special equipment, such as IC programmers or emulators. All required software is available as a free download, including a C compiler
