Android robot project built on the Arduino Nano sumo the Sumo robot motor control Qik2s9v1 dual serial motor controller module, Xbee for communication via your Android phone with Bluetooth module is being used. The body of a robot made of 3-dimensional printer writer. Android robot application codes and Arduino Nano robot codes given
source: madebyfrutos.wordpress.com/2013/01/12/bobobot alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22289.zip
Publication date: 2013/11/09 Tags: arduino projects, avr project, microcontroller projects
600W Class D amplifier Ir2110 (4 ohm 8 ohm 1000W)
Class D amplifier circuits switch mode switched work thanks so much less material with higher power can give. 600w high power 2 provided with circuit bridge connection (4 ohm speakers with 1000w) for a total of 4 PCs FDP2532 mosfet is used (instead of IRFP250) mosfet driver circuits is controlled with the Ir2110 MOSFETs. Class D amplifier circuit used coils 30uh worth Ei33 core wrap tie wire 0.4 mm 7 pieces parallel the author 14 tour either said
NE555 timer IC against excessive current draw on the amplifier Board protection circuit-65v supply line connected to the serial 0.05 Ohm 4w voltage across the resistor resistor according to Ir2110 entegrelerini took the sleep mode. 600w Class D amplifier project pcb and schema drawings.
Arduino Android-Roboter-Projekt
Android Roboter-Projekt baute auf den Arduino Nano sumo die Sumo-Roboter Motorsteuerung Qik2s9v1 zwei serielle Motorsteuerung -Modul, Xbee zur Kommunikation über Ihr Android-Telefon mit Bluetooth-Modul verwendet wird. Der Körper eines Roboters, der aus der 3-dimensionalen Drucker, writer. Android-Roboter Anwendungs-codes und Arduino Nano
