Arduino transistors, LEDs, motors, MOSFETs, various electronic components, circuit connection diagrams that will be of great use for Arduino projects, Arduino circuits or those who are new to Arduino programming … Circuit diagrams are simple to understand Detailed studies on the color codes of the resistors used in Arduino circuit connections ….
Arduino Connection Diagram List
Arduino Button GND connection, Button 5V connection, Button 12V connection, Built-in pullup, Using potentiometer, Photoresistor, Optocoupler inputs
Arduino Led, Lamp, Dual LEDs, Dual Color LED Connections, Arduino Relay, Mosfet, Buzzer, Sound Amplifier Connections, Arduino Triac, Speaker Connections, Arduino DC Motor, RGB Led Strip Led, Encoder Connections
Bidirectional Voltage Level Converter 3.3V to 5V, Bidirectional Voltage Level Transformer 3.3V to 5V with TTL / CMOS converter, TTL / CMOS converter (6 inputs / outputs) with voltage divider,
Arduino Microphone, Arduino Servo Motor Connections, Arduino Port Replication, 7 Segment Use, Arduino 7 Segment (Common Anode), Multiplexer, LED Array
Arduino LCD HITACHI 44780, Arduino I2C with an LCD HITACHI 44780, Arduino NOKIA LCD (Basic) with 7 segments use with Arduino MAX7221 (Common Anode)
Arduino Unipolar stepper motor drive (Basic 1), Arduino A Bipolar stepper motor drive (Basic 1), Graphical LCD connection via Arduino I2C
Arduino SD Card, Simple 3.3V Power Supply Connection, Arduino Temperature Sensor (LM35), RTC (DS1307), Video, VGA Connection
Arduino Keypad, PS2 Keyboard Connections, Arduino IR Receiver, IR Transmitter Link, Arduino MIDI Interface, Multiple Buttons Using 1 Analog Input
Digital Temperature Sensor (DS18B20), Simple Rain Sensor with Arduino, AC input, Port Expander (PCF8574xx), Shift (74HC595), Motor Drive (L298), Stepper Drive (L293)
EEPROM connection via I2C, Arduino Distance Sensor, Digital Potentiometer (MCP4161), DAC (MCP4921)
RS485 Node, DMX Controller (Basic), Resistor Color Codes, Ceramic Capacitor Codes, Polyester Film-Mylar Capacitor Code, Push Button Default, Simple Rescue, Rotary Encoder
Arduino Logical Analyzer, Current Sensitivity, Arduino Component Tester (Basic), Simple Transistor Comparison Table
Example Arduino Connection Schemes
source: http://www.pighixxx.com/abc-arduino-basic-connections/
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25931.zip
Publication date: 2018/06/10 Tags: arduino projects
Arduino Externe Schaltung Anschlussdiagramme
Arduino Transistoren, LEDs, Motoren, MOSFETs, verschiedene elektronische Komponenten, Schaltungsanordnungen, die von großem Nutzen für Arduino Projekte, Arduino Schaltungen oder diejenigen, die neu in Arduino Programmierung sind … Schaltpläne sind einfach zu verstehen Detaillierte Studien über die Farbcodes von die Widerstände in Arduino-Schaltungen verwendet ….
Arduino-Verbindungsdiagramm-Liste
Arduino GND-Anschluss, 5V-Verbindung, 12V-Anschluss, Eingebauter Pullup, Potentiometer, Fotowiderstand, Optokoppler-Eingänge
Arduino Led, Lampe, Dual-LEDs, Dual-Color-LED-Anschlüsse, Arduino-Relais, Mosfet, Summer, Sound-Verstärker-Anschlüsse, Arduino Triac, Lautsprecheranschlüsse, Arduino DC-Motor, RGB LED-Streifen Led, Encoder-Verbindungen
Bidirektionaler Spannungswandler 3,3V bis 5V, bidirektionaler Spannungspegel Transformator 3,3V bis 5V mit TTL / CMOS-Wandler, TTL / CMOS-Wandler (6 Eingänge / Ausgänge) mit Spannungsteiler,
PWM VU-Meter Tesla Audio IR2110 TL494
Previously I shared the quality Tesla Coil Circuits in Solid State Tesla Coil. This tesla coil drive circuit is controlled by tesla bobini according to a slightly different sound signal. TL494 IR2110 IGBT Tesla coil control doing a kind of tesla vu-meter or vu-tesla control can be controlled by motorda instead of high power PWM cycle tesla coil …
The first tesla coil driver circuit used old tube TV or monitor EHT high voltage transformer. EHT transformer is already used in many high voltage spark project. There is ready high voltage winding. In the first version IR2110 unused TL494 output is powered by BD139, BD140 transistors and IRFP660 MOSFET is driven. Frequency range between 10kHz ….. 180kHz
Tableaux de connexion des circuits externes Arduino
Transistors Arduino, LED, moteurs, MOSFET, divers composants électroniques, schémas de connexion de circuits qui seront d’une grande utilité pour les projets Arduino, les circuits Arduino ou ceux qui sont nouveaux dans la programmation Arduino… Les schémas de circuits sont simples à comprendre Des études détaillées sur les codes de couleur de les résistances utilisées dans les connexions des circuits Arduino….
