ADuC845 Experiment Board
| Updated on August 3, 2019
Analog Devices products that aduc845 microcontroller useful for an experiment card circuit size, although small aduc845 tests all have links aduc845 Test kartısp, the UART, input and output connections, RS232, USB (FT232) programming, etc. .. all the details are. In addition, Analog Devices “Windows Serial Downloader” program there.
aduc845-v3-analog-devices-pcb-deney-kart
aduc845-v3-development-board-pcb
Source: http://kju.wemif.net alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-16095.zip
Publication date: 2011/09/02 Tags:
1 Comment “ADuC845 Experiment Board
    0-350V High Voltage Laboratory Power Supply Circuit
    Will be very useful, especially in electronic laboratory power supply dc voltage between 0 and 0 to 350V current is adjustable from 400mA. 4 on the power stage MOSFET spw20n60s5 control lm712 op amp used on the floor. Clean for a healthy voltage rectified mains voltage is not used directly in the power output 600mA 270V 270V ac required trofo rectified dc voltage is controlled around 380v.
    Power supply 350volt under the full power of 152W 400mA low power may seem to be, but this is the highest voltage for the current low-voltage, more current can be drawn, but in this case, MOSFETs in the more power will be spent actually before I share “Regulated power supply for the relay bypass circuit” is added yield more is high.
