The balance robot on the Board Lmc660 op amplar lm339n analog circuit despite being checked with the very successful works. ADXL105 acceleration measurement circuit and ENC03 angle sensörleride. Motor driver used to run stable points of the circuit in the L293D resistance instead of potentiometers yerleştirlmiş has one trimpot control circuit 5 robot. The application value of a robot project, but I don’t know the market and the sensors.
Source: wa4dsy.com/robot/balancing-robot/analog-balancing-bot
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18735.zip
Published: 2012/03/23 Tags: analog circuits projects
2X100W Transistor Amplifier Circuit 2SC3280
2X100 amp circuit other transistor amp based on slightly different output NPN-PNP transistors instead of just NPN type is used quiescent current adjustments to not need to do (fixed) I am sure many, including people found this setup process does not like 🙂 printed circuit board PCB layout have been successful in addition to tone control and feeding solids collected on a single pCB.
2x33v ac dc operating voltage of the circuit 2x46v 300w output voltage of the transformer can use it for 8 ohm speakers are 4-ohm speakers to be used on a larger cooler should be used or even fans should keep a low supply voltage ..
