Available facilities within the quite regular, useful system has been cordless drill power supply help with a few pieces amateur transformer winding reel machine made transformermeister the spin count to an electronic circuit used instead of the previously shared “Hand made transformer winding machine (winder)” article @ 45mehmet with comments reported by the calculator method or the “PIC16F877 counter circuit with the coil round PicBasic” article you can use the shared circuits
source: elforum.ro/viewtopic.php?f=205&t=129059
Published: 2013/04/28 Tags: interesting projects electronics
PICKIT2 Update ( new pic microcontroller support)
Recently for a business pic18f46k22 programming we need to, but PICKIT2 software pic18f46k22 support said 🙂 though the error message, I do not remember Unsupported Part etc … a strange opening had fortunately just picproj on the forums @ t2 teacher’s share issues that came to my mind Pickit2 Clone upgrade was mentioned, the “pk2devicefile.dat” file to the C : \ Program Files folder PICKIT2 threw it into the directory where the software is installed smoothly pic18f46k22 programmer programs the way we were able to clone and PIC16F1847 PIC18F45K80 microcontrollers tested in addition
Transformator wickelrollenanordnung mit Akku-Bohrschrauber
Verfügbare Einrichtungen innerhalb der recht normalen, nützlichen System wurde Akku-Bohrschrauber Stromversorgung mit ein paar Stücken Amateur-Transformator Wicklungsrolle Maschine gemacht Trafogemeister die Schleuderzahl zu einer elektronischen Schaltung verwendet anstelle der zuvor geteilten “Hand gemacht Transformator Wickelmaschine (Wickler ) “Article @ 45mehmet mit Kommentaren von der Rechner-Methode oder der” PIC16F877 Zählerschaltung mit der Spule Runde PicBasic “Artikel können Sie die gemeinsamen Schaltungen verwenden
