Active Subwoofer filter circuit based on the frequency between 18 Hz 200 Hz ne5532 op ampar setting. Subwoofer Filter circuit power supply 15v dc rectifier +-7815, gathered on a single pcb pcb li regulator 7915 times the design of very high quality material, the placement of entrances, exits, etc. on a regular circuit pcb layout sketch he wrote material values.
Source: un-sound.com/board/index.php?topic=13065.msg114846 alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19255.zip
Published: 2012/07/14 Tags: audio control circuits
USC LCD Computer CPU RAM Indicator PIC18F2550
Computer CPU RAM Display PIC18F2550 microcontroller circuit board on your computer with the USB communication that uses CPU and RAM as% of the value of 2 × 16 LCD screen also displays the time information is also giving. Computer software in C # with Microsoft Visual Studio 2010 HiTech C18 prepared by the microcontroller software source code and all of the eagle pcb circuit, given the diagram drawing.
Aktiv Subwoofer 18Hz-200Hz Filterschaltung NE5532
Aktive Subwoofer Filterschaltung basierend auf der Frequenz zwischen 18 Hz 200 Hz ne5532 op ampar Einstellung. Subwoofer Filterschaltung Netzteil 15V DC Gleichrichter + -7815, versammelt auf einem einzigen PCB-LP-li-Regler 7915 mal das Design von sehr hochwertigem Material, die Platzierung von Eingängen, Ausgängen, etc. auf einer regulären Leiterplatte Layout-Skizze schrieb er Materialwerte .
