Microcontroller 8052 8051 Projects Code Library
| September 8, 2024 Updated
Following the 8052, 8051 how much use I do not know, but quite a large code library 8051 8052 projects, 8052 8051 circuit and a lot more applications where a rşiv share wanted additional Linux software ISP programmer with the transferor’s.
There are about 250 files “codelib.htm” file and can be accessed by clicking on the links to be used without internet files “codelib.htm” file set
Published: 2011/06/07 Tags: ,
1 Comment “Microcontroller 8052 8051 Projects Code Library
    TDA2003 amplifier circuit
    TDA2003 amplifier circuit made ​​with 12w output power operating voltage from 18v dc dc 8v … integrated single-source supply 3.5 amp current draw at full power operating voltage that varies according to the idle current draw of 50mA. TDA2003 amp circuit’s printed circuit board schematics, layout drawings, materials list. A simple amplifier circuit integrated in quite cheap price
