78xx Series of positive voltage regulators for the same module that you can use for different pcb drawings circuits, but are drawing on the pcb the pcb 2 coolers of diode bridge rectifier, filter capacitor has just enough to connect the dc output of the transformer, etc sources (pc power supply, dc adapter, etc.) If you want to use, you don’t have to actually use the dc source with 1000f capacitor bridge diyotada you don’t have to, but at least if the reverse connection acts as the cost of protection for important it:)
78xx Regulator Module for Integrated eagle pcb, schema files:
For 78XX Regulator Circuit Module PCB
Published: 2011/03/05 Tags: power electronic projects, simple circuit projects
5W MOSFET Class-A Amplifier Single Ended Project
For a long time I was thinking about making myself a good class a amp, next time after you fix the mechanical failure before the truck and the min, I said something like Pila access your listening pleasure and decided to make this single-ended amplifier 5w amplifier, a long time ago when I was really satisfied me that this was the experimental sound of the amp.
As a single-ended amplifier circuit is very successful, 4-5 m is a square room sound power
enough, I think, especially with a good pair of speakers ‘ rest and she’il (high-sensitivity 90dB or more) can be very, very good efficiency.
A single-ended amplifier circuit is very simple, but really want a quality work, as much as I can, I tried not to compromise on quality.I would definitely recommend a similar circuit for those who do.
Let’s start from the first open-circuit, the circuit is pretty simple, there’s a supply, 24v
