6-Legged Robot Project PIC18F46K20 microcontroller and XBee modules based on two robot’s body, legs and so on. parts such as printed circuit boards prepared with a plaque. Processing is easier for plaque PCBs are used in a very robotic projects. PIC18F46K20 prepared by assembly source software. Asm and hex code there. Also ares proteus pcb, isis’s simulation files.
In addition to the same project have a version made with microcontroller PIC16F886
Sourcelar: innovelectronique.fr/2009/12/08/robot-hexapode-robot-fourmi/ – ac-limoges.fr/sti_ge/spip.php?article36 alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18888.zip
Published: 2012/05/16 Tags: microchip projects, microcontroller projects
PWM Motor Control Circuit PIC12C509
Especially RC model, model to the application type has been designed motor control circuits printed circuit sizes too small … different a few versions all there in the PIC12C509 mükrodenetleyic used PIC12C509 output is usually IRL high-power series MOSFETs are the source asm code given pcb files dwg, dxf format ..
