Winamp before writing Visual Basic for IR control circuit PIC16F627 RS232 RS232 port on the computer’s IR transceiver circuit and control circuit I shared winamp.
This circuit instead of IR control with RF transceiver module is doing. Pic16f84p solid receiver that connects to the serial port of the computer, there are two different versions made with PIC12C508. All resources have been sharing scheme eagle, printed circuit board, etc. cc5x codes prepared by the compiler.
Winamp Control Circuit
Source: goo.gl/BZ9X Winamp Control Circuit Alternative link:
RF Winamp Control Circuit 433MHz Transceiver RS232
Published: 2010/09/12 Tags: microchip projects, microcontroller projects, pic16f84 projects
Simple Flyback Driver Circuit MOSFET
Circuit quite simple but quite high voltage flyback transformer of placing the television or monitor EHT transformer typically used in this poje song writer seems to have its own transformer.
CAUTION very high voltage flyback driver circuit produces output capacitor during operation, be careful, MOSFETs, pay attention to the zener diode circuit connection before running the insured Electricity Line, Use protective glasses
