Very nice design motherboard cpu cooler to cool the MOSFETs used in the most excellent single source of supply + 40 volts is not symmetric
Class A Amplifier circuit 30w output power at 4Ω speakers are powered by +40 v supply voltage Mosfets IRFP240 used 4 was prepared with PCB Layout View and Print output Sprint Sprint Layout Viewer Program can use for free
IRFP240 30W Claas-A Mosfet Amplifier
Today, after a rather long time collecting the money and development ideas, a prototype of the channel finally put into operation! Amplifier, I called the “Krypton”, work in a class with a quiet current of 2A and max power is 30W 4Ω . I sound more than satisfied.
IRFP240 Mosfet Amplifier 30w (single-ended class-A) Alternative link :
Published: 2008/02/14 Tags: audio amplifier circuits, transistor amplifier
LED Night Light Circuit Transformerless
Made with six white LED night light without a transformer, making it simple easy-to- Be Careful attention to high voltages are present Circuit Thanks to our brother Murat BAYGIN primarily a very nice application
Incandescent or fluorescent light bulb (energy saving bulbs) 9-11W energy spend night lights made of ultra-bright LED night light that is close in energy expenditure 1/4W. Low power consumption due to LED lighting is growing day by day. As seen in the figure that a bad night lamp ideal for saving bulb box creates a box
Sehr schönes Design Motherboard-CPU-Kühler zur Kühlung der MOSFETs in der besten Single Source of Supply + 40 Volt ist nicht symmetrisch
Class A Verstärkerschaltung 30w Ausgangsleistung bei 4Ω Lautsprechern werden mit +40 V Versorgungsspannung versorgt Mosfets IRFP240 verwendet 4 wurde mit PCB Layout View und Print Output vorbereitet Sprint Sprint Layout Viewer Programm kann kostenlos verwendet werden
IRFP240 30W Claas-A Mosfet-Verstärker
Heute, nach längerem Sammeln von Geld und Entwicklungsideen, wurde endlich ein Prototyp des Senders in Betrieb genommen! Der Verstärker, den ich “Krypton” nannte, arbeitet in einer Klasse mit einem leisen Strom von 2 A und einer maximalen Leistung von 30 W und 4 Ω. Ich klinge mehr als zufrieden.
