Power supply circuit 1.2v – 30 volts adjustable voltage 0 – 10 amps have short circuit protection features adjustable fan control lm337 mosfet buk416 been designing reinforced negative regulator LM358 opamp designed with solid control. Prepared with Eagle’s circuit schematic and PCB drawings
30V Regulated Power Supply Circuit
I would like to share with you my project dual power supply. The project was created on paper so you do not have full documentation to the tiles that have been made in a very simple way using a special pen in addition to platelet stabilizer.
These tiles bought from documentation in an electronics store. Brief characteristics of the power supply:
-AC has two independent branches with galvanic isolation -Output power supply can operate as a series or parallel
-Additional output 5V and 3A current-limited -System has thermal protection which the heat sink temperature of 95 ° C disconnects the output from the load
-Threshold load shedding when the voltage drop at the output will be below the limit set for the help switch “CUT OFF” 0.7V, 3V and 12V -OVERLOAD Overload Protection that shuts off the stabilizer in the power supply, the reset button to return to work the stabilizer
The power supply voltage used the four measures based on ICL7107 converter and a temperature gauge on the system ATMEGA8 PLED display that I bought on Allegro. Each meter has its own voltage DC / DC converters in order to isolate the mass of the system.
For cooling, the power supply used a very quiet and efficient fan size 12cm x 12cm company NMB. The transformer has the power of 600W and provides 2 x 24V voltage.
Source: elektroda.pl Power Supply Circuit schematic pcb files alternative link :
Published: 2010/02/07 Tags: atmega8 projects, microcontroller projects, power electronic projects
SMPS Electronic Transformer for Halogen Lamps 12V 150W
12v 150w SMPS electronic transformer for halogen lamps. On the market are very similar to halogen driver circuit BJT types of transistors (mje13005) used cardiac triggered if the transformers used et34 220k potentiometer circuit can control the brightness of the halogen lamp.
Halogen Lamps 12V 150W Power Supply
