SLA7062M Motor Control Circuit 3 Axis CNC Project
| July 31, 2024 Updated
CNC motor control card from the computer’s LPT port kullanılbiliy communication is made​​. Drivers at the unipolar stepper motor driver integrated Sanken SLA7062M used SLA7062M 3 amps of power has integrated CNC control circuit operating voltage of 46V eagle printed circuit prepared with the scheme’s drawings.
3 Axis CNC Circuit SLA7062M Motor Control
sanken-SLA7062M-cnc-motor-dirver-lpt-step-motors
cnc-control-Bord-sanken-motor-driver
SLA7062M UNIPOLAR STEPPER MOTOR TRANSLATOR DRIVER
sla7062m
Combining low-power CMOS logic with high-current, high-voltage power FET outputs, the Series SLA7060M translator/drivers provide complete control and drive for a two-phase unipolar stepper motor with internal fixed off time and pulse-width modulation (PWM) control of the output current in a power multi-chip module (PMCM™). There are no phase-sequence tables, high-frequency control lines, or complex interfaces to program.
Source: goo.gl/k8FU SLA7062M Motor diriver circuit CNC Project files Alternative link:
Published: 2010/09/26 Tags: , ,
1 Comment “SLA7062M Motor Control Circuit 3 Axis CNC Project
    Thermometer Circuit DS1820 ATmega32 Siemens S65 LCD
    Thermometer circuit board ATmega32 used on the LCD display DS1820 sensor used in the Siemens S65 mobile phone graphic LCD LS020
    ATmega32 project’s source code S65 LS020 bitmap bmp files for graphic LCDs and PCBs (sprint layout)’s files. Ds1820 information on GLCD LS020 kittens, and dog imaged with animations
    ATmega32 DS1820 Thermometer Circuit
