Hi Fi 100 Watts Power Amplifier Circuit 2SA1943 2SC5200
| Updated on September 5, 2024
100 watts power amplifier circuit based on BJT type transistors 2SC5200 transistors one (npn) one 2SA1943 (PnP) kalital have to design a circuit on the circuit in addition to about 1.5 seconds in speaker retarding’s solid. Diagrams in PDF format, print circuit layout in the list of ingredients had been given.
power-amplifier-2sc5200-2sa1943-100w-hi-fi-amplifikator-devresi
2sc5200-2sa1943-100w-hi-fi-amplifier-circuit
100w amplifier circuit features;
Supply voltage: highest. +-45 volt
Power output: 4 ohm speakers with the most high: 120 Watt
Frequency response: 15-100 000 Hz-3dB
Harmonic distortion: 100W 1 kHz 0.1%; 100W 10 kHz 0.011%
inter modulation distortion: 0.31% 80W 80 7 kHz in
Input sensitivity: approx. 0.55 V
Source: zosilnovace.eu Alternative link:
Publication date: 2011/01/28 Tags: ,
1 Comment “Hi Fi 100 Watts Power Amplifier Circuit 2SA1943 2SC5200
    Voltage Controlled Oscillator Circuit VCO
    Voltage controlled oscillator (VCO) LF442, TL082 op-amp based on the operating voltage of + -12 volts dc symmetrical sine, square wave with frequency adjustment on the sound effects can be created.
    * Octave control voltage 1V
    * 4 octave 1V control voltage inputs.
    * 1 linear control voltage input.
    * Fixed sync input.
    * Rectangular waves can be set between 10% and 90%
    * Frequency range 20kHz sub-audible ultra-sonic (about 0.1 hertz)
    * +12 V supply 23mA current consumption.
