2.1 Preamp Bass Filter Circuit 4558 Opamp
| Updated on December 8, 2019
For the 2.1 amplifier project, I prepared a 4558 opamp preamplifier subwoofer filter circuit. The circuit is based on 2 4558 opamps, with the main audio input and bass output volume adjustment. Power supply symmetrical + -15VDC
The PCB drawing was not very regular because I had to prepare it very urgently, but I ran it without problems.
The original circuit diagram was a bit confused above, I cleaned the schematic I used the bass output potentiometer in the PCB drawing stereo 22k. (I used mono pots in the tests)
The bass frequency of the circuit is not adjustable I don’t know what the frequency range is, but I didn’t calculate it, but it gave a very good bass sound.
amplifier-project-i-prepared-a-4558-preamplifier
2.1 Preamp Circuit diagram
2.1-preamp-circuit-diagram
Note: If you want to make the bass filter frequency adjustable, you can make potency connection according to the following diagram. Remember to connect the wire to the chassis from the metal part of the pots that have more work than I’ve left in the detailed assembly. Capacitor values: 104 (100nf) 682 (6.8nf) 224 (220nf)
bass-filter-frequency-adjustable
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-26275a.zip
Publication date: 2019/12/08 Tags:
1 Comment “2.1 Preamp Bass Filter Circuit 4558 Opamp
    2.1 Filtre de préampli Bass Circuit 4558 Opamp
    Pour le projet d’amplificateur 2.1, j’ai préparé un circuit de filtre de subwoofer de préamplificateur opamp 4558. Le circuit est basé sur 2 4558 opamps, avec le réglage principal du volume d’entrée audio et de sortie des basses. Alimentation symétrique + -15VDC
    Le dessin du PCB n’était pas très régulier car je devais le préparer de toute urgence, mais je l’ai exécuté sans problème.
    Le schéma de circuit d’origine était un peu confus ci-dessus, j’ai nettoyé le schéma J’ai utilisé le potentiomètre de sortie des basses dans le circuit imprimé dessin stéréo 22k. (J’ai utilisé des pots mono dans les tests)
    La fréquence des graves du circuit n’est pas réglable, je ne sais pas quelle est la plage de fréquences, mais je ne l’ai pas calculée, mais cela donne un très bon son de basse.
