c 4 1SH29B lamp used bass, treble, gain and volume controls able supply 200V 15mA and 5v 200mA DC separate circuit diagram in key areas of current and voltage data indicated pcb print circuit drawing layout quite been good over-current for the author 10w transformer He trained with the circuit. 1SH29B sprint circuit’s layout has been prepared by the PCB on file.
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-15224.zip
Published: 2011/06/10 Tags: audio control circuits
12V 7AH Battery Charge Circuit LM317
12-volt batteries in many applications are being used , of course, to charge the battery in the case according to the quality of a circuit required LM317 circuits built with the 12v 7 y island 4 battery can charge this circuit equivalents ( 7,812 ) low-power ups, inverter devices is also used . Quite low in the cost of the battery charging circuit
password for the file zip
Hi,
pass: 320volt.com
