12V Relay with a few changes made over a simple electronic circuits, made of shock. Shock NE555 integrated circuit used in addition to the 0.05 mm wire from the relay coil windings added 200 sip. High voltage low current during the test, but be careful and wear safety goggles fused electrical line
Simple Electric Shock Circuit
The EL luminous films seem to come more and more in vogue among hobbyists. For this reason I made the film with my broken clock some experiments. Mainly it was about to build an appropriate voltage converter.
To save a lot of work at the transformer I have wrapped a relay coil (12V) for this purpose. The already existing wire stays on the spool and is soldered to cable. Thereafter, a further coil is wound on the old.
This coil is made of thin copper wire (approximately 0.05 mm), with about 200 windings have been applied. Also there again solder wire, and finished the transformer.
Publication date: 2010/08/01 Tags: analog circuits projects, simple circuit projects
Counter, Temperature Measurement Circuits PIC18F2550 PicBasic PRO
In general, advanced circuit PIC18F2550 usb-connected with 4 simple applications were shared in this article’s source files and projects isis simulation codes have PicBasic pro
00-99 reciprocating single channel with counter circuits and LM35 temperature measurement circuit and the third temperature measuring channels. Press the button three channels connected to the circuit LM35 temperature sensor information is displayed on the display
