IO board with PIC18F4550 microcontroller based on the pic accomplished many projects and have visual basic source code open source project müasit to their development PIC18F4550 analog input and digital input and output ports via USB port control a lot of reading done ..
Examples;
USB Relay Controller (open, close)
USB LCD control
USB Volt, Ampere, Watt Meter
USB CNC Control
USB Temperature Meter
USB Humidity Meter
USB Stepper Motor Control
USB RC Servo Controller
Source: circuitvalley.com/2011/09/pic-18f-usb-io-board-with-analog.html
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18654.zip
Published: 2012/03/20 Tags: microchip projects, microcontroller projects
Motor Driver Circuit TB6560AHQ and Additional Circuits
Author TB6560AHQ bipolar stepper motor driver circuit integrated based on the available kits on a lot by adding CNC project has prepared a bit complicated but looks CNC motor control people interested in the solution to be easy to also LPT control board opto Kubla card and one separate Card TB6560AHQ diagrams and printed circuit and Mach3’s settings are illustrated description about your CNC project uygulamasa additional circuits, pCB drawings can be useful ..
