Voltage Controlled Oscillator Circuit VCO
| Updated on September 5, 2024
Voltage controlled oscillator (VCO) LF442, TL082 op-amp based on the operating voltage of + -12 volts dc symmetrical sine, square wave with frequency adjustment on the sound effects can be created.
* Octave control voltage 1V
* 4 octave 1V control voltage inputs.
* 1 linear control voltage input.
* Fixed sync input.
* Rectangular waves can be set between 10% and 90%
* Frequency range 20kHz sub-audible ultra-sonic (about 0.1 hertz)
* +12 V supply 23mA current consumption.
Octave-control-Square-Pulse-with-sequencer-keyboard-Sync-Effects
VCO circuit sample sounds
What is VCO ?
voltage-controlled-oscillator or VCO is an electronic oscillator whose oscillation frequency is controlled by a voltage input. The applied input voltage determines the instantaneous oscillation frequency. Consequently, modulating signals applied to control input may cause frequency modulation (FM) or phase modulation (PM). A VCO may also be part of a phase-locked loop.
Source: musicfromouterspace.com Alternative link:
Publication date: 2011/01/28 Tags:
1 Comment “Voltage Controlled Oscillator Circuit VCO
    Electronic Piano Circuit Attiny2313 Simple Audio Project
    Atmel ATtiny2313 two 1.5V AA batteries powered electronic piano circuit connected in series (3V) can be operated. PB3 – PB4 16 on pins 15 and 32 ohm speaker connected to these pins as exit. 13 pieces in varying shades of sound produced by this tone. AVR programming beginners a good example for people.
