USB RGB Led Strip Control PIC18F2550 Mosfet Driver Circuit
| Updated on July 25, 2024
RGB LED control circuit based on the PIC18F2550 microcontroller communication is done via the computer’s USB port can be controlled RGB LED strip through the program (rapid color change, slow color change)
LEDs can change color according to the ambient temperature DS1821 temperature sensor is used for sensing temperature values ​​can be determined on the program. PIC18F2550 IRFZ 34N MOSFET outputs rgb led strip of reinforced (12volt 13.5cm) driven
ds1821-rgb-led-baglanti-120x120 rgb-serit-led-surucu-devre-mosfet-pic18f2550-ds1821-120x120
USB PIC18F2550 RGB Led Strip
Source: steffenschuette.de RGB Led Strip Mosfet Driver Circuit alternative link :
Publication date: 2010/05/20 Tags: , , ,
1 Comment “USB RGB Led Strip Control PIC18F2550 Mosfet Driver Circuit
    ATtiny24-44-84 Adapter PCB Testing for the programming
    Atmel series testing, programming circuits attiny24, attiny44, attiny84 adapter so you can use the integrated micro-controller circuit. Circuit eagle pcb, pcb diagram welding drawings are on file amended PIC microcontroller can be used in series. STK500 development board stated that the author uses.
    ISP connection on the adapter socket and SMD types are integrated within the socket.
