Previously LM2575 (1 amp), and the LM2576 (3 amps) switching regulator ICS sharing about applications that have been LM2575, LM2575 high power mosfet to increase the output current by adding the received power regulator circuits of this type are usually integrated in the upgrade I wanted to share, it’s no wonder.
Note: without pictures I don’t share the projects I made, but this application, with the exception of when you’re in a higher power, it’s worth a try 🙂 also, this circuit is the main source of Elektor
LM2575 Adjustable DC-DC converter
2V…30V adjustable power supply circuit circuit regulated 5 amp switched between the first application.. the LM2575-ADJ LM2575 writes can be performed with the set (ADJ version) 16 pin dip PCB accordingly prepared a sheath used LM2575-ADJ TO220 case.. you can use a p-channel MOSFET IRF9540 used (RDS, front, losses due to gate voltage, p-channel mosfet required the use of) in the output flow to meet the power necessary to have a 100uh coil
If the fixed output of the LM2575-5 LM2575-3.3 are cancelled if the potentiometer is used in the schema and S-a writer will be a short circuit in
LM2576 DC-DC converter
In this application, the LM2576-5 Output Voltage 5v 8 amps of power used is the same that is used in the application schema according to the model, two integrated power, there are voltage differences
source: aca-vogel.de ve static.elitesecurity.org (elektor uygulaması)
all files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25461.zip
Publication date: 2016/04/23 Tags: dc dc converter circuit, power electronic projects
Car Amplifier Circuit with STK4131-II
Complete car amp in a project stk4131 amp solid-II solid KA3525A DC-DC converter (SG3525) is located in the Filter section based on the bass opampli also tl074 DC-DC converter, the primary windings of the transformer circuit used; 2×6 2x type 9 secondary species (connected in parallel with wire Section 2 1mm) of the circuit diagram I do not have expresspcb source prepared with a program writes the values of all the materials on the PCB there is PCB drawing
eproje forums @northeastern PCB design is a circuit that is shared by ugur Yilmaz made by fasting. Thank you to the people who contributed to prepare
Aktualisieren Sie Die Ausgangsleistung MOSFET LM2576 LM2575
Zuvor LM2575 (1 amp), und den LM2576 (3A) Schaltregler ICS-Austausch über Anwendungen LM2575, LM2575-high-power-mosfet zur Erhöhung des Ausgangsstroms, indem die empfangene Leistung Spannungsregler-schaltungen dieser Art sind in der Regel integriert in die Upgrades, die ich teilen wollte, ist es kein Wunder.
Hinweis: ohne Bilder, die ich nicht teilen die Projekte die ich gemacht habe, aber diese Anwendung, mit der Ausnahme, wenn Sie in eine höhere macht, einen Versuch ist es Wert 🙂 auch, diese Schaltung ist die wichtigste Quelle von Elektor
