Willem programmer series motherboards, especially in computer technical services were those most commonly used to write the bios I’m sure he still is. Willem programmer Microchip PIC, MCS-51, Atmel AVR, 93Cxx, EPROM, EEPROM, FLASH, I2C etc.. Aiyar pcb circuit can be a very integrated programs (top and bottom placement) scheme and additional program files are modülül 8050.
Willem programmer Integrated and supported;
EPROM: 27C64, 27C128, 27C256, 27C512, 27C010, 27C020, 27C040, 27C1001 M27C1001, M27C2001, M27C4001 27C080 (A19), M27C801, M87C257 2716(Vpp25V), 2732, (adapter DIP24) 2764, 27128, 27256, 27512, 27010, Vpp12.5V
EEPROM: 28C65, 28C64, 28C128, 28C256, 28C512, 28C010, 28C020, 28C040 M28C16A/17A (DIP28) (adaptör ya da campır ile) 28C16, XLS2816 (DIP24)
FLASH Memory: 28F64, 28F128, 28F256, 28F512, 28F010, 28F020 MX26C1000, MX26C2000, MX28F1000, MX28F2000 Am28F256A, Am28F512A, Am28F010A, Am28F020A (New command erase/prog.) inte; i28F001BX, 28F004, 28F008, 28F016 29F64, 29F128, 29F256, 29F512, 29F010, 29F020, 29F040, 29F080 29F001, 29F002, 29F004, 29F008, 29F016, 29F032
Seri I2C EEPROM 24Cxx: 24C02, 24C04, 24C08, 24C16, 85C72, 85C82, 85C92 24C32, 24C64, 24C128, 24C256, 24C512
Microwire EEPROM: Data 8bit 93C06, 93C46, 93LC46, 93C56, 93C57, 93C66, 93C76, 93C86 8bit, AT59C11, AT59C22, AT59C13 CAT35C102, CAT35C104, CAT35C108 16bit 93C06A , 93C46X, 93C56, 93C66, 93C76, 93C86 (NS)
Microchip PIC serisi: 16C84, 16F84, 16F84A , 16F627/16F628 12C508/A, 12C509/A, 12CE518, 12CE519, 16C505 16C620 16C621, 16C622, 16CE623, 16CE624, 16CE625, 16C710/711 ICSP cıkışı ile programlananlar 16F870, 16F871, 16F872, 16F873, 16F874, 16F876, 16F877 PIC16F873A, PIC16F874A, PIC16F876A, PIC16F877A
Atmel Flash Memory: AT29C256, AT29C512, AT29C010A, AT29C020, AT29C040, AT29C040A W29EE512, W29EE011, W29EE012, W29C020(128), W29C040 PH29EE010 (W29EE011) ASD AE29F1008 (AT29C010), AE29F2008 (AT29C020)
Atmel Flash Memory: AT49Fxxx (Subset 29Fxxx) (Byte-by-Byte Programming) (Software Data Protection) Command seq. 5555/AA, 2AAA/55, 5555/A0 AT49F512, AT49F010, AT49F020, AT49F040 SST39SF010, SST3S9F020 , SST39SF040 AT49F001, AT49F002 , AT49F008A Command seq. 555/AA, 2AA/55, 555/A0 Am29F512, Am29F010, Am29F020, Am29F040, HY29F080 29F002, 29F002T, Pm29F002T
Serial Peripheral Interface (SPI): EEPROM Mode0 (0, 0) AT25xxx, W95xxx [Atmel] AT25010, 020, 040 (A8-A0) AT25080, 160, 320, 640, 128, 256 (A15-A0) [ST] W95010….256, Microchip 25×010 – 25×640 25010, 25020, 25040 25C080, 25C160, 25C320, 25C640, 25C128, 25C256, 25C512 AT25HP256, AT25HP512 AT25HP1024 CAT64LCxxx (16bit DATA IN/OUT) use Socket 93Cxxx CAT64LC010, CAT64LC020, CAT64LC040
Atmel EEPROM (page prog.): (Software Data Protection) AT28C256, AT28C010, AT28C040
Nonvaltile SRAM (DS12xx): DS1220, DS1225Y, DS1230Y/AB, DS1245Y/AB, DS1249Y/AB
static RAM (Test RAM): 6116, 6264, 62256, 62512, 628128
EPROM winbond, SST: Electrical Erase Chip W27E512, W27E010, W27C010, W27C020, W27C040 SST27SF256, SST27SF512, SST27SF010, SST27SF020 MX26C4000 Vcc = 3.3-3.6V SST37VF512, SST37VF010, SST37VF020, SST37VF040
Flash Memory SST, Sanyo: SST28SF040A , LE28F4001
8051 Experiment Board and Additional Circuits Module
Prepared for the 8051 series microcontrollers experiment cards and additional modules. All cards eagle drawings have been prepared by the printed circuit board and scheme. Other modules arranged pic except for the main card, av series can be made to work with microcontrollers.
Additional cards: Thermometer (SMT160-30 SMT160-30) RS232, LCD I2C EEPROM, external memory (62256), DAC expansion module (8255), Button module with 8 × 8 LED matrix, led module, AT89C2051 module
