Parking sensor circuits made without using ultrasonic sensors
| Updated on August 5, 2024
Generally, parking sensors, ultrasonic sensors are used in the circuits used in the sensor circuit is shared very different handmade, fitted to the rear bumper of the car “capacitive proximity sensor” was called to the construction’s’s pictures and information.
Parking Sensor Circuit with PIC12f675 Test
With the same method used in different microcontroller has two circuits used in both series one microchip pic 12f675 circuits belonging to the other with the 16F628 was performed with software written in the C language, diagrams and drawings have PCBs.
Source: http://www.forosdeelectronica.com/ alternative link Parking sensor circuits project files:
Publication date: 2010/11/13 Tags: ,
1 Comment “Parking sensor circuits made without using ultrasonic sensors
    8051 Development Test Circuit 8051 Example Code
    8051 microcontroller is a useful post for programs designed to try the circuit. As a Test circuit has rs232 serial port the display, compress, ISP, IC2 (AT24C02), eeporom, led, pushbutton, IR receiver parts.
    In addition to the RS232 serial port test circuit’s display buzzer ISP IC2 (AT24C02) eeporo button, IR receiver section I have led. Protel prepared by the printed circuit board, bill of materials and schema files are
    8051 Development Board
