100A TIG Welding Circuit IGBT UC3845 IRG4PC50U ETD59
| Updated on August 3, 2019
SMPS (switch mode power supply) electronic welding machine circuit UC3845 control integrated based on the power transformer for the ETD59 used integrated 6 from exit smallest drive transformer coupled this transformer at the output of the IRG4PC50 the (600volt 27amp’s) IGBT’s. Instead of providing ETD59 supply out of the system with low-power SMPS circuit TOP224Y used. Operating current 3 mm by 100 authors mention that the electrodes have been used …
100 A welding circuit diagram does not seem too complicated, but look for very high power is stronger than him AmAlArdA author Aromatizers whole circuit has managed to pack the PC power supply box after box looks nicer paint. PCB Drawings “sprint layaut” while drawing diagrams “splan” made ​​with
100a-aku-sarj-devresi-smps-uc3845-igbt-top224-switch-mode-power-supply
top224-uc3845-smps-charger-circuit-100a
Source: invertorov.net.ru
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-16186.zip
Publication date: 2011/09/17 Tags: , , ,
1 Comment “100A TIG Welding Circuit IGBT UC3845 IRG4PC50U ETD59
    Multifunction Digital Amplifier Project TDA7294 ATmega32 TDA7313
    A lot of work in the ATmega32 occur when project featuring a beautiful rose amp amp volume control on the floor in the TDA7313 TDA7294 is used in the upgrade process. Digital FM radio (tuner control) remote control (RC5 Protocol) heat hours) DS1307) indicators Londness (bass sound strengthens) featured tone control, weekly programming, encoder control, audio output operates according to the external control (lighting shutdown, etc..) Section etc. .. There is a long list.
