Author “Super final version flyback driver,” he said, but not so super stable than other simple flyback driver to control at least 555 UC3844 SMPS control IC is used instead. Flyback MOSFET driver circuit used irfp260, 12:18 ohm resistor connected to the source through the legs made of current limiting.
Attention flyback driver circuit produces high voltage capacitor connection Observe caution + – If you connect the high voltage polarity may be large explosions before running the insured Power Line circuit, protective goggles
Source: https://www.youtube.com/watch?feature=player_embedded&v=655uZTywQ5I
Publication date: 2012/05/26 Tags: power electronic projects
Digital Voice Recorder Circuit 60 120 Seconds
The position of the material, is indicated on the print. (Refer to the wiring diagram.)
ISD1760 (60sec), ISD1790 (90sn), ISD17120 (120 seconds)
1N 4007
7805 3 LEDs bulbs
1 Piece condenser microphone
3 pcs 3 pcs 1K 4.7K 82K 1Adet
2 pcs 10K
7pcs 100nF 2 Piece 4.7 mF 1 Quantity: 470mf
Press the left key sw-Recorder
4 buttons, one for aux in jack connector
(Registration: yellow, busy, green, power: red LED)
