SMPS power supply circuit 80 turns on the primary winding 40 +40 will be two seventh round after the first 40 will be wrapped around the top of the secondary supply uc3842 ninth round of last 40 laps of the primer more
primary 0.3mm
uc3842 supply 0.5mm 9 rounds
secondary 0.5mm wire 4 pralel
Driver MOSFETs BUZ90, BUZ92, IRF830, P6N60
UC3842 Switch mode power supply
UC3842 SMPS Power Supply Circuit pcb schematic alternative link:
Publication date: 2008/06/07 Tags: power electronic projects, smps circuits, smps projects, smps schematic
Inverter for 12V Strobe Circuit
The inverter is constructed with the use of a small transformer core coming from the ATX power supply. Can be used with the inverter transformer stand-by or transformer control transistors kluczującymi. From the original core, delete the original winding and wind new 14zw Order code. original, five with in Order code. secondary and 350 with in the secondary winding
You should also check whether the column is the central core air gap. if it does not have to be sanded down one of the columns of the central core. The inverter has an output voltage stabilization at 320V which causes wide supply voltage range. The inverter is working correctly from 4V voltage With a supply voltage of 12V repetition frequency of flashes can occur 10 times a second. (10Hz)!
