Tone-Controlled TDA7377 Amplifier Project
| Updated on August 4, 2019
I guess you have to know the power amplifier tda7377 integrated a high-performance chip compared to the price.
TL074 Tone Control opamp DC rectifier used in the project on the floor low operating voltage DC 8V to 18V on the PCB is integrated with solid filte… 50…the AC outlet 12V DC 60W transformer you can use highest.
I used an old ATX power supply for ATX chassis boxing of the boxes is very helpful for this kind of transactions. All the circuit ATX power supply compatible safe, at least around me was sleeping. I tried so hard to not cut the size of the heatsink alone. The old transformer 5+1 out of the system approximately 70-80w it looks like. In the circuit, o posted by Box necessarily must be connected to the places .As shown with screws from the bottom with the tip of the cable and the cable hooked up. In fact, drilling the screw holes plaque can be connected directly to the pots according to height.
Tone Control on the floor Psychic (middle volume setting) Low (audio treble adjustment) from the bottom of the PCB capacitors or potentiometer connected as you can see in the pictures, by isolating the PCB from the top of her legs can be worn with macaroons.
tda7377-amp-stereo-120x120 tda7377-amp-stereo-2-120x120 tda7377-amp-stereo-3-120x120 tda7377-amp-stereo-4-120x120
Tone-Controlled Stereo Amplifier Test Video
proje-atx-tda7377-amp-stereo
proje-atx-tda7377-amp-stereo-2
proje-atx-tda7377-amp-stereo-3
tda7377-pcb
TDA7377 Circuit schematic
tda7377-75-stereo-schematic-120x120
TDA7377 pcb files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25447.zip
Publication date: 2016/04/22 Tags: ,
2 Comments “Tone-Controlled TDA7377 Amplifier Project
    Industrial Fan driver circuit
    Designed for the control of the fan motors used for cooling purposes. 4A 24V DC motor with soft start cooling fan is driven with the control card has made; and supply of other system components and is intended to avoid sudden loading peaks. The thermostat with the control card to be connected to the ignition system is being taken up.
    Klangregelung TDA7377 Verstärker-Projekt
    Ich denke, Sie wissen, die Endstufe tda7377 integriert einen Hochleistungs-Chip im Vergleich zum Preis.
    TL074 Klangregelung opamp DC-Gleichrichter im Projekt verwendet werden, auf dem Boden niedrige Betriebsspannung DC 8V bis 18V auf der platine integriert ist solide filte… 50…der AC-Steckdose DC 12V 60W Übertrager, die Sie verwenden können höchsten.
