It’s quite strange that so many projects are being done with some 555 circuits. “Domino’s” 555 timer 555 circuit is an interesting electronic circuit with a chip that is prepared based on the different LEDs and photodiodes made a lot from each other they trigger it’s a domino effect, the author is also the project “Domino’s” is called 🙂
Light photo diode which is connected into the circuit when it detects the initial 555 # 3 pin output LED is burning and thus the loop circuit to trigger the other begins.
Circuit 555 and a few passive electronic components out of the audio version ldrli exist in a circuit board with CR2032 3V battery to 5V used as a power source is actually more appropriate to reduce the size of the ideal circuit but it came cr2030
Domino Effect Circuit Diagrams 555
source: http://relwin.hackhut.com/2011/03/01/555-timer-contest-entry/
Publication date: 2016/10/15 Tags: 555 timer circuits, analog circuits projects, led projects
SPDT Relay and DPDT Relay
In SPDT spdt relays (Single Pole Double Throw SPDT Relay) are very useful in some applications due to its internal configuration. It has one common terminal and 2 contacts in 2 different versions can be normally closed and the other opened, or it may be normally open and the other closed. So basically you can see the spdt relay as a way to toggle between 2 loops: when there is no voltage at the coil is one circuit receives current, the other is not and when the coil gets voltage is reversed.
Der Domino-Effekt Mit der 555-Schaltung
Es ist sehr merkwürdig, dass so viele Projekte durchgeführt werden, die mit einigen 555-schaltungen. “Domino ‘ s” 555-timer-555-Schaltung ist eine interessante elektronische Schaltung mit einem chip, der bereit ist, auf der Grundlage der verschiedenen LEDs und Photodioden, die eine Menge von jeder anderen, die Sie auslösen, es ist ein domino-Effekt, der Autor ist auch das Projekt “Domino ‘ s” genannt wird 🙂
Licht-Foto-diode, die verbunden ist in die Schaltung ein, wenn es erkennt die ersten 555 # 3-poligen output-LED brennt, so ist die loop-Schaltung zum auslösen des anderen beginnt.
