In a single-layer winding toroid core inductance useful program for the calculation simple installation for inclusion does geektir and 80kb in size toroid core type toroid core size, type, etc. of the wire to be wound. After you enter information such as the end of the data .. Author: K1QW
inductance calculator
this program calculates inductance vaule and winding information for a single layer
inductor wound on either a powdered iron or feritte toroidalcore. To use program, follow these steps;
1: select metric (mm) or english (inches) unit of length.
2: select type of core material (powdered iron or feritte).
3: use the drop down menus to select from industry standart desingations for a specific core
size an material
4: in the frame labeled “calculate” enter a target inductance vaule and/or number of turns
5: click on the “solve for.” button for the parameter you want. the program
will display the desired result in the appropriate text box.
the maximum size of wire that can be accommodated in the selected core is displayed, as well as the
required total length of wire (not including any allowance for external leads)
core dimesions are also shown, analog code information and suggested frequency range.
NOTE: For more information on individual itens, click on the question mark
(?) in the title bar and then on an item in the dialog box.
inductance calculator Program:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19547.zip
Publication date: 2012/08/20 Tags: electronics software tools
Classical Audio Quality Control Guitar Effects Circuit Archive
I say classic, but still popular, especially in the realm of DIY Electricians musicians who make use of the circuits that have a very high quality roland, boss, ibanez, Nobels, Paia, korg, etc.. circuits and exclusions of famous brands (power supply, mixed circuits, etc.). finds ..
It is an interesting software, thank you.
