GPS is difficult to apply a great resource on a project can be difficult to find parts, but sources in our country ccs codes may work for you or pic18f8722 circuit diagram Nokia 6610 LCD (GLCD 128 × 128) gives an idea about the use of rides
Dual display: colour road map (left) and detailed text messages (right) both with LED backlight
Up to 120 TMC messages are stored in memory
Auto/manual TMC message scrolling
GPS position locator/follower optional
Map navigation with mouse sensor and/or micro joystick
Map zoom 10km to 80km in 10km steps
City and area presets preconfigured
High quality NXP TEF6901AH chip used for best performance
Integrated RDS-RBDS radio data demodulator
Nokia 6610 Graphics (GLCD) LCD Connection information
pin 1 VDD 3.3 V LCD supply
pin 2 Reset
pin 3 SDATA Serial Data (Synchronous data – can use SPI port on Microchip PIC MCU”s)
pin 4 SCLK Serial Clock
pin 5 CS Chip Select
pin 6 VLCD 3.3V LCD supply
pin 7 NC Boş
pin 8 GND LCD – ground
pin 9 LED- (0V) Backlight LED Katod
pin 10 LED+ (6V) Backlight LED Anod
Source: techdesign.be PIC18F8722 CCS C TEF6901AH GPS Traffic Info schematic pcb source code alternative link:
Publication date: 2008/11/07 Tags: ccs c examples, microchip projects, microcontroller projects
SG3525 12 Volt 220 Volt Inverter Circuit
Control integrated now classic SG3525 used MOSFETs IRFZ44 Transformer computer from the power supply removed (EI33) on the bandages removed half the values required for the re-wrapped MOSFETs that are connected to the ends (primary) 2 × 7 round 1.5mm wire output winding (secondary) 130 round 0.3mm in chapter 12 volt input wire coil value is not so important for the trials would not use either on your pc power supply 12v 5v output coil can use the filter circuit in the power of 120 watts
