4x TDA7381 TDA7386 TDA7385 TDA7360 TDA7384 TDA7383 TDA7385 TDA7386 TDA7360 Car Amplifier circuits for the PCB Double surface can be used to integrate PCBs have not tried the third leg of the integrated datasheet links, check the file
TDA7560
4x45w quad bridge car radio amplifier plus hsd
superior output power capability:
4 x 50w/4Ω max.
4 x 45w/4Ω eiaj
4 x 30w/4Ω @ 14.4v, 1khz, 10%
4 x 80w/2Ω max.
4 x 77w/2Ω eiaj
4 x 55w/2Ω @ 14.4v, 1khz, 10%
multipower bcd technology
mosfet output power stage
excellent 2Ω driving capability
hi-fi class distortion
low output noise
st-by function
mute function
automute at min. supply voltage
detection
low external component count:
internally fixed gain (26db)
no external compensation
no bootstrap capacitors
on board 0.35a high side driver
1.1 protections:
output short circuit to gnd, to vs,
across the load
very inductive loads
overrating chip temperature with
soft thermal limiter
output dc offset detection
load dump voltage
fortuitous open gnd
reversed battery
esd
TDA7386
4 x 45w/4Ω max.
4 x 40w/4Ω eiaj
4 x 28w/4Ω @ 14.4v, 1khz, 10%
4 x 24w/4Ω @ 13.2v, 1khz, 10%
TDA7385
4 x 35w/4Ω max.
4 x 30w/4Ω eiaj
4 x 22w/4Ω @ 14.4v, 1khz, 10%
4 x 18.5w/4Ω @ 13.2v, 1khz, 10%
TDA7384
4 x 40W/4Ω MAX.
4 x 35W/4Ω EIAJ
4 x 25W/4Ω @14.4V, 1KHz, 10%
4 x 22W/4Ω @13.2V, 1KHz, 10%
TDA7383
4 x 35W/4Ω MAX.
4 x 30W/4Ω EIAJ
4 x 22W/4Ω @ 14.4V, 1KHz, 10%
4 x 18.5W/4Ω @ 13.2V, 1KHz, 10%
TDA7381
4 x 30W/4Ω MAX.
4 x 25W/4Ω EIAJ
4 x 18W/4Ω @14.4V, 1KHz, 10%
4 x 15W/4Ω @13.2V, 1KHz, 10%
Publication date: 2008/02/28 Tags: audio amplifier circuits, ic amplifier
LM4766 Stereo 40w Amplifier Circuit
Amplifier LM4766 integrated circuit made with two channels can give you 40 watts per channel output has supply voltage of 28 volts DC Output section 2 × 0.9 mm wire used in the coil to be wound round of 20
Auto-Verstärkerschaltungen der Serie TDA73XX
4x TDA7381 TDA7386 TDA7385 TDA7360 TDA7384 TDA7383 TDA7385 TDA7386 TDA7360 Auto Verstärkerschaltungen für die Leiterplatte Double Surface kann verwendet werden, um Leiterplatten zu integrieren, haben nicht versucht, den dritten Zweig der integrierten Datenblatt Links, überprüfen Sie die Datei
TDA7560
4x45w Quad Bridge Autoradio Verstärker plus HDD
überlegene Ausgangsleistung Fähigkeit:
4 x 50 W / 4 Ω max.
4 x 45w / 4Ω eiaj
4 x 30 W / 4 Ω bei 14,4 V, 1 kHz, 10%
4 x 80 W / 2 Ω max.
4 x 77w / 2Ω eiaj
4 x 55 W / 2 Ω bei 14,4 V, 1 kHz, 10%
Multipower-BCD-Technologie
Mosfet Ausgangsleistungsstufe
Hervorragende 2Ω-Antriebsleistung
HiFi-Verzerrung
geringes Ausgangsrauschen
st-by funktion
Stummschaltung
automute bei min. Versorgungsspannung
Erkennung
Geringe Anzahl externer Komponenten:
intern festgelegte Verstärkung (26db)
keine externe vergütung
Keine Bootstrap-Kondensatoren
an Bord 0.35a High-Side-Fahrer
1.1 Schutzmaßnahmen:
Ausgangskurzschluss nach gnd, nach vs,
über die Last
sehr induktive Lasten
Chiptemperatur mit überschätzen
weicher thermischer Begrenzer
DC-Offset-Erkennung ausgeben
Lastabwurfspannung
zufällig offen gnd
Umgekehrte Batterie
esd
