TDA7293 integrated amp I used to reproduce the sound quality is really very clean “td” series about integrated change the negative thoughts I can say that this integrated
TDA7293 120v 100w Dmos Audio Amplifier
Very high operating voltage range (±50v)
Dmos power stage
High output power (100w @ thd =
10%, rl = 8w, vs = ±40v)
Muting/stand-by functions
No switch on/off noise
Very low distortion
Very low noise
Short circuit protected (with no input
Signal applied)
Thermal shutdown
Clip detector
Modularity (more devices can be
Easily connected in parallel to
Drive very low impedances)
TDA7293 Stereo 100W Amplifier Circuit
Publication date: 2008/02/28 Tags: audio amplifier circuits, ic amplifier
1000W Mosfet Amplifier Circuit Mosfet IRFP240 IRFP9240
1000 watts power quality have a design output stage 6 irfp9240 (P-Channel) and 6 irfp240 (N-Channel) used the audio input section of the lf411 JFET input a quality op-amp opamp onset 15volt zener are provided with amp circuit supply voltage + -40volt and + – 90olt two feed
Quiescent current BD140 BD139 transistors oval connected to the ends 5k potentiometer is done with an estimated half of the audio input while there was no draw current 300mA vicinity should be adjusting accordingly can, of course, the exact value is not by trial and error you will find yourself
TDA7293 Stereo 100W Verstärkerschaltung
TDA7293 integrierte Verstärker, die ich verwendet habe, um die Klangqualität zu reproduzieren, ist wirklich sehr sauber “td” -Serie über integrierte Änderung der negativen Gedanken, die ich sagen kann, dass diese integriert
TDA7293 120V 100W DMOS Audio Verstärker
Sehr hoher Betriebsspannungsbereich (± 50 V)
Dmos Endstufe
Hohe Ausgangsleistung (100 W @ thd =
10%, rl = 8 w, vs = ± 40 v)
Muting / Standby-Funktionen
Kein Ein- / Ausschaltgeräusch
Sehr geringe Verzerrung
Sehr leise
Kurzschlussfest (ohne Eingang)
Signal angelegt)
Thermische Abschaltung
Clip-Detektor
Modularität (mehr Geräte können sein
Einfach parallel zu schalten
Sehr niedrige Impedanzen fahren)
