TDA7293 amplifier integrated into a variety of high-strength and high-strength connections can be taken way before I paylaşmıt the 2x100W circuit. Can you give 100w power supply voltage TDA7293 highest + – 50 volts DC
TDA7293 Amplifier test
TDA7293 100W DMOS AUDIO AMPLIFIER
very high operating voltage range (±50v)
dmos power stage
high output power (100w @ thd =
10%, rl = 8w, vs = ±40v)
muting/stand-by functions
no switch on/off noise
very low distortion
very low noise
short circuit protected (with no input
signal applied)
thermal shutdown
clip detector
modularity (more devices can be
easily connected in parallel to
drive very low impedances)
TDA7293 Amplifier Circuits PCBs all files:
Publication date: 2008/03/31 Tags: audio amplifier circuits, ic amplifier
Simple Metal Detector Circuit
Friends at work I work I have done to my brother bi based on the metal detector circuit LM386 ICL8038 and I wanted to share with you.
Circuit whether those running the trial, but there has not been known. When set to 5 kHz output frequency of the circuit (through the switch) will see the other metals except gold. switch in the other position will not see the other metals except silver.
Circuit to try to be stuck in the ground (yellow egg sticks: D) will strike the earth with one call sooner yards and two bars poured a little water if the soil between the field survey can be more. With TDA2003 also raise the signal outputs from deeper in the soil transfer calls if we can. Unfortunately, few meters away from the following search term I do not know, but it is said that the term of up to 5 meters.
Brass rods used to make calls Visit here for more information about available address.
