10 Band Equalizer Bass Subsonic Filter Circuit TL074 TL072
| Updated on August 3, 2019
Used in the project subsonic bass filter project other filter circuit according to the more advanced input signal level adjustment, bass boost (low bass tones upgrade), 15Hz-55Hz and 40-150Hz frequency adjustment can be made circuit TL072 op amp built on. Able to control the 10-band equalizer circuit tl074 op amp circuit built on a different version of the filter circuit in addition there Subsonic Bass.
subwoofer-tl072-subbass-tl074-10-channel-equalizer-project-subsonic-filter-bass
tl072-opamp-tl074-10-channel-equalizer-project-subsonic-filter-bass
Source: forosdeelectronica.com/f16/crossover-3-vias-activo-mas-equalizador-3415/ alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19524.zip
Publication date: 2012/08/20 Tags:
3 Comments “10 Band Equalizer Bass Subsonic Filter Circuit TL074 TL072
    Battery Alarm Circuit for Model Helicopters ATtiny13
    ATTINY13 Atmel microcontroller installed on the circuit model helicopter is checking the voltage of the battery the battery (or battery) voltage circuit when the level set LEDs, buzzer, giving the alam. ATTINY13 PB2, PB1, and PB0 pin chassis yaplılarak short circuit between the alarm can be set at a certain voltage circuit has very little material, if prepared pcb printed circuit board with SMD components becomes much smaller.
    Battery alarm for model helicopters
