Previously shared power supply programmable power supply features advanced digital projects based on a study in stm32f100c8t6b.. pretty, has a detailed structure of the circuit of analog-digital mix-in panel design including all source code, pcb, etc. everything to be shared we will be useful for different projects.
digital Power supply specifications
Output voltage: 0 … 36 V (10 mV step voltage setting)
Output current: 0 … 4 a
Maximum output power: 100 W
1 mA current setting
Stabilization modes: voltage (CV) current (cc)
Setting and voltage measuring error: 0.02%, which is + 10mV
Available mounting and measurement error: 0.02%, which is + 1 mA
Fluctuations during network instability: < than 0.05% a time of instability-load current: < than 0.05% rms ripple and Noise: <1 mV (CV) is <0,5 mA (CC) recovery time when a jump of the load current: <100 ms Temperature instability: <100 ppm / ° C long-term instability: <% 0.05 Interface Type: USB (FT232RL ADuM1201 isolated) Input: 220 V ± 10%, 50 Hz Power consumption: <150 W, Dimensions: 150 x 90 x 220 mm Weight: Programmable laboratory power supply with adjustable output voltage and adjustable output current limiting 1.5 kg stabilized power source. In laboratory studies, the source for power electronics circuit development process, or as part of testing of various equipment can be used.
Source: link alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25762.zip
Publication date: 2016/10/10 Tags: arm project, power electronic projects, power supply circuit, power supply project
2X30V 250W Audio Amplifier SMPS Power Supply TOP249Y
TOP249Y SMPS circuit audio amp. From the derived parameters of the sources in the previous paragraphs, we can now choose a control circuit of switching power supply. According to the required output power we have to choose between the circuits of the topswitch GX series. Between the circuits of this series was chosen circuit TopSwitch GX TOP249Y with the maximum obtainable power of 250W when used in a ventilated Chassis and the single input power supply voltage 230V.
STM32F ARM Programmierbare Labor-Stromversorgung
Zuvor freigegebenen power supply programmable Labor-Stromversorgung features erweiterte digitale Projekte basierend auf einer Studie in stm32f100c8t6b.. hübsch, hat eine detaillierte Struktur der Schaltung des analog-digital-mix-panel-design, einschließlich aller Quellcode, platine, etc. alles, was geteilt werden wir werden nützlich sein für verschiedene Projekte.
digital Labor-Stromversorgung Spezifikationen
Ausgangsspannung: 0 … 36 V (10 mV-Schritt-Spannung-Einstellung)
Ausgangsstrom: 0 … 4 a
Maximale Ausgangsleistung: 100 W
1 mA aktuelle Einstellung
