Amplifier Circuits STK4048X STK412-170
| Updated on August 3, 2019
Sanyo STK412-170 from the series production of NGOs and STK4048X amplifier circuit diagrams and PCB drawings but no definite information can be compatible within an integrated PCB drawings of different NGOs. for example STK412-170 datasheet file when I look at the different models found in the list that caught my attention in the list STK412-090, STK412-000, STK412-010, STK412-020, STK412-030, STK412-040, STK412-150 integrates the information given probably STK412-170 for PCB drawing prepared, but it is compatible with integrated datasheet files necessary to perform comparison
STK412-170 2X180W THD 0.7% of the maximum working voltage symmetrical 2x95v STK4048X 1x150W THD = 0.008% of the maximum working voltage symmetrical 2x87v
stk4048xi-150w-amplifier-stk412-170-2-180w-amplifier
STK4048XI 150W STK412-170 2X180W pcb
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19858.zip
Publication date: 2012/09/29 Tags: ,
4 Comments “Amplifier Circuits STK4048X STK412-170
    Sierpinski Triangle Fractal Antenna Wifi Making PCB
    Sierpinski Triangle in Mathematics (Sierpinski Triangle) there was such a thing .. the author of this triangle fractal remove PCBs on a plaque made ​​WiFi antenna. Linksys WRT54GS modem’s power of attraction has increased up to 500 feet. Sierpinski triangle pcb copper clad sticker printing on both sides of the copper plate on the other side is making a face while using it as a complete chassis. Antenna RP TNC Jack connector with cable included balendajl Sierpinski triangle at the end of the solders. Application of the Sierpinski triangle has pcb drawings. Author PCB laminating machine used for printing
    Verstärkerschaltungen STK4048X STK412-170
    Sanyo STK412-170 aus der Serienproduktion von NGOs und STK4048X Verstärkerschaltpläne und PCB-Zeichnungen, aber keine eindeutigen Informationen können innerhalb einer integrierten PCB-Zeichnungen von verschiedenen NGOs kompatibel sein. zum Beispiel STK412-170 Datenblatt Datei, wenn ich auf die verschiedenen Modelle in der Liste gefunden, die meine Aufmerksamkeit in der Liste STK412-090, STK412-000, STK412-010, STK412-020, STK412-030, STK412-040, STK412 erwischt -150 integriert die gegebenen Informationen wahrscheinlich STK412-170 für PCB-Zeichnung vorbereitet, aber es ist kompatibel mit integrierten Datasheet-Dateien notwendig, um Vergleiche durchzuführen
    STK412-170 2X180W THD 0,7% der maximalen Arbeitsspannung symmetrisch 2x95v STK4048X 1x150W THD = 0,008% der maximalen Arbeitsspannung symmetrisch 2x87v
  3. ERNESTO PEREZERNESTO PEREZ
    Buenas Noches,
    Muy buenos sus proyectos, tendria algun inconveniente en subirlos en PDF, ya que mi computador no me deje ver nada de lo que he descargado de esta pagina.
    gracias por su atención.
