100 Watt Stereo Amplifier STK4231
| Updated on June 30, 2023
STK4231 2x100watt two-channel stereo amp circuit power supply circuits on the same PCB printing do not need to create additional PCBs.
STK4231 amplifier part list
  • 56k 1/4w 2x
  • 10k 1/4w 2x
  • 1k 1/4w 4x
  • 100ohm 1/4w 2x
  • 4,7k 1/4w 4x
  • 560ohm 1/4w 2x
  • 4,7ohm 1/4w 4x
  • 3,3k 1/4w 2x
  • 2,2k 1/4w 2x
  • 470pf 63v 2x
  • 100nf 63v 4x
  • 10 rounds on 10mm ferrite coil wire 1mm 3uh
  • 10uf 63v 2xt
  • 22uf 63v 3x
  • 47uf 63v 2x
  • 100uf 63v 2x
  • 100uf 100v 1x
  • 10000uf 63v 2x
  • transformer 2x30v 300watt
  • 10 Aa bridge kbu10m
  • Led 2x
This amp is so high quality that it would be playing to talk about hi-fi amplifier. HIFI amplifier-land frequency response must be direct and distortion <1% 20 - 20 kHz. Articles of the amplifier circuit again meets the above requirements in band 5Hz - 500 kHz, however, frequency bandwidth is limited, such that interference from birth. Amplifier meets the requirements of referenssivahvistimelle, which is suitable for measuring and reference use. Small, 12-24V of voltage operating amplifiers, and power characteristics when the are somewhat modest for example, the speaker sound testing. Amplifier is also called the PA-use
Publication date: 2008/01/11 Tags: ,
2 Comments “100 Watt Stereo Amplifier STK4231
    TDA7294 Multi Mode PCB 200W Stereo Mono
    An amplifier circuit with TDA7294 a simple inexpensive quality you want with a single circuit 200w Mono Stereo want you can use 2 × 100
    TDA7294 200W PCB
    TDA7294 Europe are well-known ST SGS-THOMSON Microelectronics, the company launched in 90 years on behalf of a very DMOS innovative set dictates the success rate of discharge Road. It swept away the past, linear power amplifier and integrated thick-film integrated Health, cold, hard Sound, widely used in HI-FI area, ST announced the TDA-7294, with a wide range of operating voltage (VCC VEE) = 80V more power output up to 100W, the output electric current of 10A of more spectrum, not a mistake and the characteristics of Quality performance! OP at the power rate dictates continuous output and still maintain a very low total harmonic distortion rate, peripheral circuit
    100 Watt Stereo Verstärker STK4231
    STK4231 2x100watt Zwei-Kanal-Stereo-Amp-Schaltung Stromversorgungs-Schaltungen auf dem gleichen PCB-Druck brauchen keine zusätzlichen PCBs zu erstellen.
