Solid State Tesla Coil Circuits
| Updated on July 6, 2023
Various “Solid State Tesla Coil” Mini Tesla Coil high voltage coil applications integrated project schedule based on the NE555 integrated IRF540 MOSFETs in the output is driven using a Tesla coil circuits are powered by 12v dc voltage.
CAUTION Solid State Tesla Coil circuit produces high voltage capacitor connection Observe caution + – If you connect the high voltage polarity may be large explosions before running the insured Power Line circuit, protective goggles
solidstate_tesla_coiltesla_coil
Solid State Tesla Coil 100000volts
100000volt
The schematic for the solid-state Tesla coil The high voltage is due to a high current flowing through a high reactance (remember that the inductance is large and the capacitance is small, creating large reactances in each component at a given frequency). That is what produces the corona discharge at the end of the secondary coil.
The heart of the driver is IC1, the SG3524 pulse-width modulator. The duty cycle is fixed at about 45% for best efficiency. The frequency is controlled by the resistance on pin 6 and the capacitance on pin 7. With the values shown, the frequency has a range from 200 to 240 kHz. A flip-flop inside the chip divides that by 2 so that the effective output of the driver has a range from 100 to 120KHz.
Solid State Tesla Coil Circuits Source: http://skory.gylcomp.hu/tesla/mini_tesla.htmlhttp://www.uoguelph.ca/~antoon/circ/hv/ss-tesla/ss-tesla2.html
Publication date: 2008/03/15 Tags: , , , ,
1 Comment “Solid State Tesla Coil Circuits
    PIC16F84 Development Board PLAY-PIC
    New to PIC programming a circuit that will be beneficial to your friends. Designed to work with PIC16F84. On the board buttons, LEDs and available in seven segments. Thus, when a trial programs çalıştırabilirsiniz.ayrı easily make links to outside input, LCD display and an external programmer for connection of the card’s internal connectors bulunmakta.ayrı var.9-24 volts DC voltage regulator circuit can be fed with a source.
    PIC16F84 PLAY-PIC
