Snow White Auto Wah guitar effects circuit sensitivity, resonance and decay controls built on the circuit the circuit doing the LM13700, LM324 opamps operating voltage 5v DC but less current consumed and is designed to be used on portable 9 battery. Snow White Auto Wah guitar effects circuit PCB printed circuit drawing Sprint layout pcb file prepared by the source.
Source: guitar-gear.ru/index.php?p=proj&id=114 alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19742.zip
Published: 2012/09/14 Tags: audio control circuits
Stereo Speaker Cabinet and Bass Treble filter design
Steeo Cabinet Design Peerless 810,921 high-pitched twitter and Peerless 830875 midwoofers speakers designed for but the same size as a very alternative there speaker dimensions detailed information about where the dimensions difficulties in not appropriate speakers If you can use the additional 2-way filter circuit and enclosure design pdf, Bassbox design program’s source. bb6 file there.
Gitarren-Effekt-Schaltung Schneewittchen Auto Wah
Snow White Auto Wah Gitarre Effekte Schaltung Empfindlichkeit, Resonanz und Fäulnis Kontrollen gebaut auf der Schaltung der Schaltung macht die LM13700, LM324 opamps Betriebsspannung 5V DC aber weniger Strom verbraucht und ist entworfen, um auf tragbaren 9 Batterie verwendet werden. Snow White Auto Wah Gitarre Effekte Schaltung PCB gedruckten Schaltung Zeichnung Sprint Layout PCB-Datei von der Quelle vorbereitet.
