SMPS Transformer Coil Transformer Calculation Programs
| Updated on August 4, 2019
Before “Advanced SMPS Transformer design program” ExcellentIT and “Ir2153 SG3525 Frequency Calculation Programs for Switch mode power supplies with raisers” shared a very useful programs. Programs prepared by Russian-born Vladimir Denisenko sharing a person known as a Russian electronic forum Starichok51.
Starichok51 share of 18 program until it was presented as a very popular used Russian ExcellentIT have been translated into English (this work in some programs required) at the end of a very important program that added support for multiple languages.
But there are other languages, only English and Russian General Turgidson users I would like to add that I hope the translations of technical inglizcesi make good
I’m going to tell you how to add a new language, first of all, the video option is a multiple language programs as you go
Booster Boost Buck-Boost Converter Transformer Core Ring dcdc Step-Up/Down Calculator
booster-dcdc-step-up-step-down-buck-boost-hesaplama-programi-vert
Excellent IT SMPS Switch Mode power supply transformer cores Calculator
excellent-it-smps-switch-mode-guc-kaynagi-trafo-nuve-hesaplama
Flyback Transformers Ring Core Calculator
flyback-flyback-ring-transformator-flyback-nuve-hesaplama-vert
Forward Converter Transformer Calculation Program
forward-donusturucu-transformator-hesaplanma-programi
Inductor Ring Calculator Program
inductor-inductor-ring-enduktor-hesaplama-programi
Programs a one of a similar nature but been in business done by a person because I’ve studied a lot of programs than the straightforward but so far the detailed addition can be customized or non-standard values ​​can be used, customization is nice .. “Ring” versions “for powder material “translation was called” powder “probably for a different type of core but I’m not sure …
Switch mode SMPS power supplies a lot of people dealing with the largest sorunuda this transformer, coil a lot of people, myself included, that the calculations programs come in handy
source: kazus.ru/forums/showpost.php?p=234370 alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22853.zip
Publication date: 2014/04/09 Tags:
2 Comments “SMPS Transformer Coil Transformer Calculation Programs
    TDA7294 Stereo Amplifier Circuit Of Controlled Loudspeaker-Protected Tone
    Hi guys, I used the new project again with proven performance, sound, price TDA7294 an amplifier IC. This project, in addition to double check before I share tons of “delayed and Led Excitation Speaker DC protection circuit TDA7294 Stereo” and “2X100” projects, we can say that a combination of amplifier circuit (when the minor detail differences.)
    Diode bridge rectifier circuit is required for the feed, filter capacitors, the speaker protection circuit and volume, bass, treble tone control circuit when the psychic has additional settings for the card to connect the output of the power supply transformer circuit is designed as insurance, the filter Board
    Schaltnetzteil Übertrager Spule, Übertrager Berechnung Programme
    Bevor “Erweiterte Schaltnetzteil Übertrager design-Programm” ExcellentIT und “Ir2153 SG3525 Frequenz Berechnung Programme für Schaltnetzteile mit raisers” gemeinsam eine sehr nützliche Programme. Programme vorbereitet von der Russisch-geboren Vladimir Denisenko-sharing eine person bekannt als Russisches elektronisches forum Starichok51.
    Starichok51 Anteil der 18-Programm, bis es vorgestellt wurde, als sehr beliebt verwendete russische ExcellentIT wurden ins englische übersetzt (diese Arbeit in einigen Programmen benötigt) am Ende ein sehr wichtiges Programm, das zusätzliche Unterstützung für mehrere Sprachen.
