Although simple Metal Detector circuit 555 timer chip works quite well made, the metal detector circuit according to a lot more electronic component is unused, but the fine craftsmanship of the detector part of the detector coil a bit of the good work of the days of coils already wants to
There’s a timer in the circuit 555 Metal Detector 2, In addition to the passive components used a 9V battery as a power source for winding the detector coils of enameled wire wound around nails on a board nailed to the studs and the circular made with shielded cables connected to the control circuit by the coil outer winding and the center section of shielded cable to the chassis of the coil connects to the circuit connects to the part that goes
Metal Detector circuit schematic
The Construction Of The Metal Detector Circuit
Metal Detector coils that is used for the thickness of the wire is 0.3 mm, but the diameter of the circle The author used to wrap prepared wire 0.7 mm 15cm….The number of rounds between 25 16cm (15.5 cm) after coil winding, paper tape, or electrical tape is wrapped with
with the coin of the metal detector in the test video shows how the circuit works
source: cxem.net/metal/Part6/6-20.php alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25764.zip
Publication date: 2016/10/10 Tags: 555 timer circuits, analog circuits projects
STM32F ARM Programmable Laboratory power supply
Previously shared power supply programmable power supply features advanced digital projects based on a study in stm32f100c8t6b.. pretty, has a detailed structure of the circuit of analog-digital mix-in panel design including all source code, pcb, etc. everything to be shared we will be useful for different projects.
digital Power supply specifications
Output voltage: 0 … 36 V (10 mV step voltage setting)
Output current: 0 … 4 a
Maximum output power: 100 W
1 mA current setting
Einfache, Sensitive Metall Detektor-Schaltung
Obwohl einfache Metall-Detektor-Schaltkreis 555-timer-chip funktioniert ganz gut gemacht, die Metall-Detektor-Schaltung nach viel mehr elektronische Bauteil ist unbenutzt, aber die feine Handwerkskunst der Detektor Teil der Detektor-Spule, ein bisschen von der guten Arbeit, die Tage in den Spulen, die sich schon
Es gibt einen timer in die Schaltung 555 Metall-Detektor 2, die zusätzlich zu den passiven Komponenten verwendet eine 9V-Batterie als Stromquelle für die Wicklung der Detektor Spulen Lackdraht gewickelt Nägel auf ein Brett genagelt, um die Nieten und Runder gemacht mit geschirmten Kabeln an den regler angeschlossen Schaltung von der Spule äußeren Wicklung und den mittleren Abschnitt des abgeschirmten Kabels auf das Gehäuse der Spule verbindet mit der Schaltung verbindet, die das Teil geht
Metal Detector Schaltplan
