ATX Power Supply modification Symmetric 2X30V DC DC Converter Circuit sg3525
| Updated on August 21, 2023
Symmetric SMPS auto amp supply (DC / DC converter) sg3525 PWM control integrated circuit built on the output MOSFETs are driven in two stp60n06 the power transformer transformer ei33 is most commonly used in computer power supplies
EI33 transformer handing out you do not find in the market again you can use the wrap. Prime 12v mosfet section 2 × 5 rounds (4 pcs 0.6mm wire parallel). Secondary + – 30v output section 2 × 12 tour (2 pcs 0.6mm wire parallel)
Output for bridge rectifier UF5407, BY399 diode or transistor type is stronger than I used diodes pc power supply 12v output of the diode bridge I’m using 3 of the money for the MOSFETs as irfz44, used irfp3710
ATX Supply modification
hizli-diyot-kopru-baglanti
For two-channel stereo amp circuit TDA7294, TDA7293, LM3886 integrated amp in the pictures below of the two available power supply circuit and the PC seems to state coffers placed
CAR AUDIO AUDIO power amplifiers. Converter has been made ​​according to the scheme of the Internet and it is not by me. I will describe only the transformer because the rest needs no description. Transformer won the ATX power supply model LC-ATX that I got from a friend for the rest of the proverbial beer possessed of surplus. So the cost of small, only two evenings and desire.
sg3525-otoanfi-devresi smps-dcdc-oto-besleme
source : elektroda.pl ATX Power Supply modification Symmetric 2X30V DC DC Converter Circuit sg3525 schematic files alternative links
Publication date: 2009/07/05 Tags: , ,
1 Comment “ATX Power Supply modification Symmetric 2X30V DC DC Converter Circuit sg3525
    LM1036 Digital Tone Control Circuit PIC16F628A DS1844 Picbasic
    Digital tone control circuit PIC16F628 microcontroller based on the PicBasic with the ds1844 and lm1036 use a good sample source. Pressure. Hex software and proteus isis ares pcb simulation files are cdrom drive, MP4 player or different audio sources can use.
    PIC16F628 with you and I share ds1844’l digital tone control circuit application designed long ago had tried it just kept on board. I recently heard a friend in need is a final project realization had the opportunity to practice and my friend did as a final project application.
