Siemens s65 using the Atmel ATmega128 caption to display graphics on the LCD all the resources an application prepared S65 LCD driver library, sample text and detailed graphics shared C code.
S65 application is more complex graphic LCD (given schematic diagram) is connected to the microcontroller ATmega128 directly behind the LCD not LCD 2.9-volt power supply and a few passive components oscillator is staying placement.
Atmel ATmega128 Siemens S65
The S65-Display is a 132x176x65536 color display. display use a slave SPI communication controller is unknown and can be used with an SPI clock up to 13 MHz. The software was used with an ATmega128 at 8MHz SPI clock.
Source: S65-Display-Software AVR Graphic LCD Alternative link:
Publication date: 2010/10/06 Tags: avr project, microcontroller projects
Precision CNC Motion Control Unit Encoder, Driver Interface PIC16F877
CNC control circuit PIC16F877 microcontroller used in the project’s RS232 PC connection to all floors described separately (English) source: Assembly shared MPLAB IDE software.
