Servo motor control unit to control two’s. While the other one circuit pic16F877 16f876 circuits based on the communication with the computer via RS232 serial port is doing. Kazırl backed by Assembly PCB software and schema files are made with eagle.
Servo motor control circuit
Servo interface circuit can translate the servo commands, sent through serial connection, to the servo control signal. Using a microcontroller (PIC micro) to elaborate these signals, we built an interface circuit that can support 8/16 servos simultaneously. The 8 servos version (SER8) uses a PIC16F876 (28 pins) microcontroller, the 16 servos version (SER16) uses a PIC16F877
Source: goo.gl/GTea Servo Motors Interface Circuit Alternative link:
Publication date: 2010/09/06 Tags: microchip projects, microcontroller projects, pic16f877 projects
Operated Washing Machine Control Circuit with ATmega32
ATmega32 microcontroller based on the project is already quite interesting and a professional I see this type of advanced projects ATMEL series
Some sections of the circuit MOC3043 opto diac, MOC3023 isolated with LCD and LED indicator control (presumably rc5) control and has a lot more features
Washing Machine Circuit
